« Reply #31 on: January 19, 2011, 04:35:41 PM »
Top shows the welding tip we are using for nozzels installed.
Mid show the aircraft drill we use that goes through a jig we bought.
ther are 3 of them 1 for #1 cyl 2-7 cyl and # 8 cyl shown.
When the cyl is at TDC it sprays across the bore as the piston comes down the spray comes across the piston crown.
Bottom we used a small cut off to grove the oil from the oil supply to the slant hole we just drilled and installed the nozzel in on the upper side of the main brg saddle.
« Last Edit: January 19, 2011, 04:51:13 PM by SPARKY »
Miss LIBERTY, changing T.K.I. to noise, dust, rust, BLUE HATS & hopefully not scrap!!
"Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure or nothing." Helen Keller
