I have not run the lines yet but the return is a -6 from the regulator back to the top of the tank. Am I making a big basic mistake, I thought that the pressure regulator fed the fuel rail but the diagram posted by Dan shows the regulator inlet down stream from the fuel rail working as a back pressure device. I guess that explains why the regulator has two inlets. I am feeling realy stupid about now. HELP!
Dont feel stupid, what you are talking about is a dead head system and they work for many applications. I wouldnt do one on your setup.
Try this:
tank-fuel filter-fuel pump-fuel rail in-fuel rail out-regulator in-regulator out-tank
You wont need a manual shut off.
The busa motor uses a TOS for its inertia shut off, and will shut the fuel pump off if tipped, providing you still use the OEM fuel pump power on the pump. Increase the fuel pump fuse 5 amps if you use the circuit.
If you have disabled the TOS or use other fuel pump power this is another story.
Check to see if the pump should have the filter pre or post pump. I do know these pumps are very sensitive to particulates and I have ran my filter pre pump to filter particles before they enter the pump.
The 044 or A1000 may in fact ask the filter is post.
You will need a fuel pressure gauge, and you are looking for 43 psi.
-What horsepower are you looking for?
Good luck.
~JH
