Author Topic: Post your "Things I have to change to conform to the new rules" list here  (Read 19297 times)
Offline bvillercr
Re: Post your "Things I have to change to conform to the new rules" list here
« Reply #15 on: December 01, 2010, 04:32:03 PM »
John, check with Tap Plastics. I think they're a lot cheaper.
http://www.tapplastics.com/
Brian, they don't have molded windows.  We could order flat sheets and cut to fit if they pieces long enough.  Front and sides only.
Offline thundersalt
916 REMR
El Mirage 200 MPH Club
Offline Bob Drury
« Reply #17 on: December 01, 2010, 04:50:41 PM »
  Just a question, has anyone tried forming the lexan over a stock glass curved window?   I assume using body shop heat lamps and clamps would be the way to go.  Do you cut it with a jig saw and a fine blade?  Tap plastics probably could give us the answers, or maybee if you made a paper template, it might be worthwhile to pay them to cut it.  They did my tail light lenses, and the cuts were really smooth, but I never thought to ask them what they used.
  They also sell drill bits for plastic, and I got a how-to sheet from them on the best proceedures for drilling.                                        Bob
Bob Drury
Offline bvillercr
« Reply #18 on: December 01, 2010, 05:02:11 PM »
Troy, check this out :-D
http://www.eharwood.com/catalog/product.php?productID=131
I talked with Steve the GM there, very racer friendly.  No tinting available.
Offline thundersalt
« Reply #19 on: December 01, 2010, 05:03:10 PM »
That's how we have done it. Used a small reciprocating air saw with a fine blade to cut. You can smooth sand the edges with 180-240 grit. We used regular drill bits just make sure they are sharp and go slow.
916 REMR
« Reply #20 on: December 01, 2010, 05:39:44 PM »
"It does not say anything about the class record."
Come on, Bob, you know that won't fly.
Stan
Offline 836dstr
« Reply #21 on: December 01, 2010, 08:27:33 PM »
There are special blades for cutting plastics and fiberglass. They have tungstun abrasive on the leading edge and cut smoothly. No teeth to grab material.
Offline Nortonist 592
    • http://www.artfv.com/design/fashion/
« Reply #22 on: December 01, 2010, 09:07:35 PM »
Lexan won't cut with a regular blade.  It tends to crack and break and get expensive.  If you are going to do it yourself get the right blade.
Offline krusty
« Reply #23 on: December 01, 2010, 11:13:33 PM »
Lexan cuts just fine with a regular jigsaw blade. Polycarbonate that is not Lexan will split and crack.     vic
Offline hitz
« Reply #24 on: December 02, 2010, 12:56:19 AM »
Bob, you'll need 270 degrees F. to form Lexan.
Mike, You can tell the belts are polyester if they are so stiff you can hardly tighten them. Be sure the "anti dive" belt is 2" so it might not chaff stuff.
I've bought my helmet but I got a SA2005. At my age I probably won't need one for more than 5 years more. I haven't looked seriously at the head restraints yet but I heard you have to go to a 2" shoulder harness. Sure hate to throw away my custom Autopower 3" shoulder harness for something smaller so I can spend a bunch of money on a restraint that is going to increase my cockpit exit time!
Harvey
« Reply #25 on: December 02, 2010, 06:33:18 AM »
Lexan is just a brand name for polycarbonate. They are the same. Wayno
Offline jimmy six
« Reply #26 on: December 02, 2010, 09:59:26 AM »
Dyno....Nylon belts are SFI 16.1 and Polyester belts are SFI 16.5..................JD
Offline 38flattie
« Reply #27 on: December 02, 2010, 10:22:28 AM »
Just FYI, I ordered mine here:
http://www.ridoutplastics.com/
I ordered a dark bronze tint, and it wa $312.35 for the entire car. Of course, all I have is flat glass, no curves.
http://youtu.be/89rVb497_4c
Offline Ron Gibson
« Reply #28 on: December 02, 2010, 12:19:06 PM »
No dog in this fight, I don't got no stinkin windows.  LOL
That been said. It looks to me there are lots of safety film choices, from numerous suppliers, available.
All the SCTA has to do is specify a thickness, say 6 mil or 8 mil for strength. Then require a hole, 1/8" or so punched with a paper punch or similar, somewhere on all film applications so inspectors can check if applied and thickness.
Ron
Offline dw230
« Reply #29 on: December 02, 2010, 12:51:29 PM »
Thanks Ron,
Two good ideas that I can take to the board.  :-D
