Author Topic: bellhousings  (Read 3077 times)
Offline BALS aSALT
  • Go Fast Be Safe...oh, and hold my Redbull
bellhousings
« on: November 20, 2010, 11:05:42 PM »
so has anyone tried using the quicktime bellhousing or is that one too thin and needs a blanket? it is SFI rated but i don't think its' 6.1 rated.
it is better to live one day as a lion, than it is to live one thousand days as a lamb. or maybe it is better to burn out than fade away.
Offline maguromic
Re: bellhousings
« Reply #1 on: November 21, 2010, 01:49:58 AM »
I am using one, though I had to modify it by cutting and welding the bottom and opening up the side for the reverse mounted starter for the REMR.  Tony
Offline krusty
Re: bellhousings
« Reply #2 on: November 21, 2010, 10:13:43 AM »
I used the Sonic 1/4" steel bellhousing from Tilton. Not SFI rated, but it is a full 1/4" and has a shallow bottom designed for a 153 tooth  flywheel, so no cut and patch required.      http://www.tiltonracing.com/content.php?page=list2&id=273&m=d        vic
Offline Cajun Kid
Re: bellhousings
« Reply #3 on: November 21, 2010, 11:03:56 AM »
That is the one I should have used, I did not know about it when I found out my QM was not SFI and a bit thin in a few spots.  So to eliminate all doubt, I went with Lakewood, but did have ground clearance issues. (resolved for the most part now)
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Offline 38flattie
Re: bellhousings
« Reply #4 on: November 21, 2010, 03:01:32 PM »
I ordered the Ford Fe to Muncie tranny, and ordered it SFI 6.1
Most of their bellhousings can be ordered SFI 6.1, and some can be ordered SFI 30.1
http://youtu.be/89rVb497_4c
Offline BALS aSALT
Re: bellhousings
« Reply #5 on: November 21, 2010, 06:27:48 PM »
is there a blanket for the bellhousing or does that need to be custom made? if not SFI rated?
Offline RichFox
Re: bellhousings
« Reply #6 on: November 21, 2010, 07:31:09 PM »
As far as I know that blanket deal is fairly new and really directed toward front wheel drive cars for which blow shields are not made. As you are running a BBC and blow shields are readily available I would expect the inspection people to what a blow shield. Before making any other plans I would for sure check it out with the responsible official and get a written confirmation of a blanket meeting spec.
Offline BALS aSALT
Re: bellhousings
« Reply #7 on: November 21, 2010, 11:28:56 PM »
ok will do.
Re: bellhousings
« Reply #8 on: November 22, 2010, 11:59:24 AM »
And if a correct bell housing is available, it sure makes for a much neater, tighter solution.
