Amazing how many sticks of tubing disappear when building a cage huh!?
Put a diagonal from the right side cage tube juncture (on the tunnel) to the upper right main hoop. That'll use up about 4'. vic
Hows about some in the trunk to tie in parachute/push bar? Looks good
I have been following this with some interest.... we drag raced a big block powered 1971 Camaro in the 1970s.... we never got it to Bonneville as we had always blown up all of our good parts by speedweek time.... but I wanted to.... I see that the rule book definition of engine swap is NOT the same anymore.... it USED TO STATE that the criteria included bell housing bolt pattern, cylinder head bolt pattern and intake manifold bolt pattern- which would have made the Pontiac Big Chief heads illegal in production as the intake bolt pattern is not the same as a standard big block Chevy.... but that has now changed.... I am curious though.... did the information you receive clearly state thay your block design met the criteria for it to be considered and engine swap and did you get it in writing?... the "in writing" part and the possession thereof may be critical at record certification time.....The cage structure looks like it is going to be really good when its all done!I hope to see you in tech!
