Author Topic: 1973 camaro AA/CGC  (Read 120900 times)
Offline old chevy truck
Re: 1973 camaro AA/CGC
« Reply #105 on: January 24, 2011, 01:08:44 PM »
Look at the up side. The AA/CGALT record is 6 mph less than the AA/CGC record. 246mph to 252mph.
Offline BALS aSALT
  • Go Fast Be Safe...oh, and hold my Redbull
« Reply #106 on: January 24, 2011, 03:51:23 PM »
don't tell anyone , but.................................i'm shooting for both :-D :-D :-D
it is better to live one day as a lion, than it is to live one thousand days as a lamb. or maybe it is better to burn out than fade away.
Offline Buickguy3
« Reply #107 on: January 24, 2011, 03:52:03 PM »
     Even if it doesn't sat it, watch that "Spirit of the rule" thing. It'll get you every time.
Doug  :evil: :cheers: :cheers:
                   [America]
Offline BALS aSALT
« Reply #108 on: January 24, 2011, 03:52:50 PM »
Very nice.
I think you might have moved yourself into altered with the subframe. Check rule 5.D.3. I hope I'm wrong (one of those gray area interpretations of the rule)
thanks brian, i'll double check, then call lee and see what he says. THANKS
« Last Edit: January 24, 2011, 03:55:28 PM by BALS aSALT »
Offline bvillercr
« Reply #109 on: January 24, 2011, 03:55:51 PM »
You could put a blower on it and run AABGALT and it's under 250 same with A. :cheers:
Offline BALS aSALT
« Reply #110 on: January 24, 2011, 07:02:21 PM »
well i'm glad i have options.
Offline BALS aSALT
« Reply #111 on: January 26, 2011, 08:26:54 PM »
man, i can't believe this. :-o :-o :-o :-o :-o it seems that thundersalt was right. :? :? :? my new subframe and frame connectors bumped me out of classic gas coupe and right into classic gas altered. one of these days i'll figure out what class i'm building for. well i guess i should have read the rules 101 times and not just 100. :roll: :roll: :roll: :roll: :roll: ok so now i'm back to building a 1972 camaro to run AA/CGALT. instead of mechanical fuel injection, i'll run EFI. everything else will be the same except for engine set back. i'm going alittle more than the 2% in CGC.
« Reply #112 on: January 26, 2011, 08:38:22 PM »
  Oh well... Altered is better anyhow :-D
  We set the engiine back as far as we could in the 222 camaro and still get the heads off without going under the cowl.
« Last Edit: January 26, 2011, 08:40:29 PM by jl222 »
Offline BALS aSALT
« Reply #113 on: January 26, 2011, 09:02:39 PM »
yeah..............it sounds racier. :-D :-D :-D :-D :-D :-D
« Reply #114 on: January 26, 2011, 09:03:36 PM »
One more hick-up  -  non stock EFI moves you into AA/GALT (out of AA/CGALT). The record there is 274 and change. Keep reading!
Offline BALS aSALT
« Reply #115 on: January 27, 2011, 12:45:28 AM »
you're killing me, or i should say....the rule is killing me.........ok back to mechanical.
Offline BALS aSALT
« Reply #116 on: January 30, 2011, 01:27:27 PM »
ok got the final word from mr.sykes jr. my build is good to go in CGC. i have a letter from him that says so. so there. and since i have continued with the build, here is what i have so far. subframe and connectors, main hoop, hallow bar, forward a pillar bars, sill bars, and what we are calling tunnel bars.
Offline BALS aSALT
« Reply #117 on: January 30, 2011, 01:28:53 PM »
here is a close up of the fit and trim.
Offline BALS aSALT
« Reply #118 on: January 30, 2011, 01:30:19 PM »
one more
Offline BALS aSALT
« Reply #119 on: February 09, 2011, 12:50:46 AM »
here is this weeks progress. i am really liking how it is coming.  :-D :-D :-D
