Author Topic: Alcohol compression ratio question  (Read 25896 times)
Offline racergeo
Re: Alcohol compression ratio question
« Reply #15 on: October 23, 2010, 09:48:49 PM »
  Wonderful, are you actually Jack Dolan? Don't be modest he is the most wonderful one!
Offline stay`tee
« Reply #16 on: October 24, 2010, 07:28:09 AM »
The streamliner with a 430" Rodeck SB is at 16.5. Add 5% of the yellow stuff to compensate for the 5K feet between sea level and  B-Ville and you should be back at sea lavel HP. Trust me this is safe. We ran at Ascot for seven years (CRA champions two years, Davis / Wirth racing) and had no problem with a Rodeck at 16.0. on alcohol. I ran 15.0 on 92% in Jr. fuel in the 1966 with 60 degrees lead. Best ET 9.87 at 200 even with a 310 CI cast iron SB and cast iron heads. Looking back I think it would have been better to run 50 degrees. Not because it would be easier on the engine but I think it would have gone faster. Be brave. The Wonderful One
Dont wish to hijack this topic, quick question,,, what is the approximate HP% loss in a n/a engine between sea level and Bonnerville??
Offline hotrod
    • Black Horse photo
« Reply #17 on: October 24, 2010, 11:38:19 AM »
Standard atmospheric pressure is considered to be 29.92 in hg, the typical barometer at Bonneville due to altitude ranges from about 25.84 in Hg to 25.37 in Hg based on standard atmospheric tables. That implies that an NA engine will be down on power by about:
25.84/29.92 = 0.8636  down 13.64%
25.37/29.92 = 0.8479  down 15.2%
http://www.landracing.com/forum/index.php/topic,1506.0.html
Larry
Offline interested bystander
« Reply #18 on: October 24, 2010, 01:38:39 PM »
Without tipping his hand, Wonderful 1 is a forever Lions Dragsrip fixture, now streamliner builder.
Because of the Witness Protection Program nothing more can be divuldged.
5 mph in pit area (clothed)
Offline maguromic
« Reply #19 on: October 24, 2010, 01:51:46 PM »
There are a lot of suspects on this board.  :evil: Tony
Offline stay`tee
« Reply #20 on: October 24, 2010, 04:23:39 PM »
hotrod,, thankyou for the link,  contains the information i was looking for :cheers:
« Reply #21 on: October 24, 2010, 04:31:07 PM »
Wonderful One's car at Christman's about a year ago.
Offline racergeo
« Reply #22 on: October 27, 2010, 04:01:11 PM »
  So what engine and class is this car ment to run? Tell us more Rex.
Offline John Noonan
« Reply #23 on: October 27, 2010, 09:15:37 PM »
It's Tim Kraushaar..not Jack Dolan.. :wink:
« Reply #24 on: October 27, 2010, 09:59:36 PM »
I think that Tim told me it was going to be a BFS (B Fuel Streamliner) and I think they are looking to run next year. I really haven't heard about it since I talked to Tim about a year ago or better. Maybe the "Wonderful one" will chime in and give us an update.
