Author Topic: Remote oil filter...will hose size affect oil pressure?  (Read 5544 times)
Offline Jonny Hotnuts
« on: October 09, 2010, 11:53:38 AM »
I was told that I shouldnt run a hose bigger then a #8 because the oil pressure will drop too much.
My thoughts are that the bearings are the restriction where the head pressure is made and the oil pump-pressure regulator are the same, so how how does a hose size to the filter affect pressure if everything else is the same?
I could see it taking a second more to build pressure with the larger ID.
~JH
jonny_hotnuts@hotmail.com
*Andres Segovia
Offline Kato Engineering
Re: Remote oil filter...will hose size affect oil pressure?
« Reply #1 on: October 09, 2010, 12:28:40 PM »
it is a overall length and amount of turns / bends type of thing.
we build then with nothing less than a #8
#10 is common
you must be certain that the end fittings or if / when it goes thru a reducer / coupler that the fitting does not have a restriction too.
but I know that you know that allready.
Offline robfrey
    • carbinitelsr
« Reply #2 on: October 09, 2010, 10:50:37 PM »
Keep lines short, straight as possible and large. Kato is correct. Assuming a wet sump, there is a way to block the pressure valve (solid spacer instead of spring) and set up a new adjustable pressure relief at the entrance to the block. My engine machinist says this works well on dirt oval cars and is common.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
« Reply #3 on: October 10, 2010, 04:04:15 PM »
Try to avoid any hard bends or right angle bends or fittings
Offline 1212FBGS
    • http://www.motobody.com
« Reply #4 on: October 15, 2010, 06:11:45 PM »
bigger hoses will give less internal surface drag and will allow for more volume.....
