...and now Rob Frey has gone a completely different route..........Thoughts, Anyone?
Here are some thoughts that Rob and I have followed in our design: First, the entire car is to be designed in 3D solid model before the anything is purchased or welded. This allows us to look in detail at the problems we will face in the manufacture and assembly steps. Hopefully, this will eliminate/mitigate the gotchas that invariably pop up in projects and help keep the costs down.
Second, build and load the design to have the CG and CP in the most optimum locations. We don't want to build a car, then try and figure out how to make it stable by loading weight in the nose/tail or build an oversize tail fin to adjust the CP. Everything we plan on putting on the car has a reason for being there and is hopefully the most aerodynamically efficient it can be.
Third, when it comes to the flat vs. non-flat bottom design, here is what we came up with. Let's assume we have a flat bottom design makes 3000 pounds of down force. What happens if we only need 2000 pounds of down force to maintain traction? Obviously, there is no "aero tuning" that you can do to adjust the down force generated by the flat bottom. That extra 1000 pounds of down force becomes nothing but drag. On the other hand, what if you need 4000 pounds of down force to maintain traction? Where do you get it? Add weight?
That is the idea behind the wing on the rear. Rather than try and control the airflow under a flat bottom car, we decided that it made more sense to let it flow and manage it with effective aero design. Using the wing, we can dial in/out down force during a run. If we need more traction, add more wing, if not, get reduce the drag a wing producing lift causes by decreasing lift (down force). The rear wing on our design is capable of putting out in excess of 10,000 pounds of down force via a change in angle of attack and use of the flap at 400 MPH. We don't think we will need quite that much, and we believe that is way more than you could get from just a flat bottom design.
