You guys are talking apples and oranges and coming up with banana splits.
As it was already pointed out, the issue with car 433 was specific to El Mirage and had nothing to do with a record being set. They had been running in the wrong class and needed to recalc their points so they'd have the correct starting line position. They could have entered their Camaro as a streamliner if they wanted to. It doesn't having any bearing whatsoever unless they qualify for a record.
I don't have a dog in the fight, but from what I have read on this forum, I understood that entry of the wrong class on your entry form was absolute loss of points.
http://www.landracing.com/forum/index.php/topic,7482.0.html
Mike, you and your dog read it wrong. The rule says that if someone were to go out and qualify for a
record (keep in mind this is El Mirage we're talking about) but be entered in the wrong class then that qualifying run would be looked at as if it never happened. No points, no record. You can't switch the class designation on the paper work after the fact to make good and pretend like you ran in the class you meant to run in. Like I said, you have to physically run in the right class to get the record. The old way was that you were done for the weekend if you did this. Someone apparently thought this was a little harsh so now you can re-pay, re-number, re-tech, re-run, re-qualify, and re-certify if you're really so set on setting a record in the right class. The points race is a big deal for some.
Those of you with a discerning eye will recognize that the above is exactly the same situation as the Salt Cat ordeal. Same deal, two different venues, same basic rule. Wow, imagine that. Consistency.
I personally don't understand where the expectation for the SCTA to bend its rules and break protocol when a mistake is made comes from. If you don't like being part of an organization that actually respects the integrity of the rules that they live by then you might want to find somewhere else to race. Apparently, from the comments I've seen on this thread, it sounds to me like there is another sanctioning body that will let anything fly to make their participants happy. Sounds like a racers utopia to me. No rules. Free records for everyone. Everyone gets a trophy. No such thing as a mistake. Nothing but back pats and atta boys for everyone!
That last part was sarcasm by the way for those that couldn't read the sarcastic tone in my voice.
Nonetheless, best of luck to the Salt Cat guys. Go get 'em.
