Joe thank you for your post, it is good to hear from a racer at the event that sees the big picture.
I was not at Bonneville however have spoken with racers and officials that were there regarding the tire situation that ensued.
I know that in the past years at Bonneville I have seen many racers blister tires from over spinning them on the salt building up heat and then the blistering starts, these racers have been known to simply return to the pits and install another rim/tire and then proceed to make further runs and motorcycle techs/officials never got a chance to see the damaged tires.
With the new policies the SCTA motorcycle officials have put in place the racers cannot make a pass, kill the tire and return to the pits without the SCTA motorcycle officials knowing about the situation.
This year I know of 6-8 tires that as Joe mentioned lost rubber in the center of the tire.
2-3 from one P-P bike, 2 from a turbo bike, one from a 1000 GSXR with a road race used throw-away tire (should have never been brought to the salt), heard a turbo 1000 started to blister one however kept the tread on...
Unless a racer over-spun his/her tire and then left the SCTA officials and motorcycle tire specialist were able to see all of the racers and take data from them regarding, HP, fuel management/traction control, type of tire/slick/compound etc.
The information is more than has ever been collected at an SCTA event and will go along way to making it safer for the racers, I have seen tires loose all of the rubber from over-spinning and yet still maintain air pressure however it seems that these race only tires are only losing the center section where the heat is being applied and none of the racers were even aware of the blistering until after the runs were over.
I am spending along time writing this in between company emails and see that Joe has already mentioned some things I either was going to or did mention, one thing that should be noted, the bike that lost the most tires was not a Turbo or Nitrous bike, it never hit 200mph or above yet due to lack of proper throttle control/modulation or traction control the rider as Joe mentioned spun the tire for miles and even after blistering the slick and race tires was able to keep the bike upright as no air loss occurred.
I was not aware that a racer was able to install a non conforming tire after hurting a race tire, thank you for that information, it would be interesting to see the tires in person and compare them to what I have seen in the past...oh wait I am sure they are in the SCTA trailer and can be seen at El Mirage..
It was great feedback from Fred, Jamie, Racergeo ...lets continue to learn from this and make it safer as we go.
I don't feel that Bubs is going to allow riders to run 200+ on ZR tires however I would get that in writing before I trailered out there and found that I needed correct tires.
Has anyone got it in writing they are reversing the tire rules? I have not heard that however my sources are just Tom and Van, I am sure there are more people on the internet that have better information/experience regarding this issue.
Be safe everyone...even you VeeTwin
