Author Topic: LSR Tires  (Read 3085 times)
Offline hombre
LSR Tires
« on: August 16, 2010, 08:08:31 AM »
Where can I source 18" motorcycle LSR tires?
Offline Warp12
Re: LSR Tires
« Reply #1 on: August 16, 2010, 04:02:03 PM »
What speeds do you plan to run? What is the record in your class?
Offline hombre
Re: LSR Tires
« Reply #2 on: August 16, 2010, 08:31:40 PM »
Should go over 200 now... but not up to class record of 240+.
Offline Warp12
Re: LSR Tires
« Reply #3 on: August 17, 2010, 03:53:01 PM »
What size tires do you need? Width/aspect ratio front and rear?
Offline hombre
Re: LSR Tires
« Reply #4 on: August 17, 2010, 04:20:44 PM »
Front 120/70, rear 240/40; both in 18" to fit the CF rims.
Currently have ZR tires, but I understand the rules for 200+ will be changing soon.
Offline WildBro
Re: LSR Tires
« Reply #5 on: August 18, 2010, 01:13:29 AM »
ECTA does not have a tire rule change coming.  You will be fine with the ZR 240 tires.
I believe these 240 tires are the only tires tested over 270mph.
aka: Tenno Celeritas
Offline hombre
Re: LSR Tires
« Reply #6 on: August 18, 2010, 03:56:51 AM »
Thanks, Bill!
I thought I read the rule was changing, my error.
Offline wrongway
Re: LSR Tires
« Reply #7 on: August 18, 2010, 08:30:49 AM »
Thanks, Bill!
SCTA is doing the rule change.
Offline Morpheus
Re: LSR Tires
« Reply #8 on: August 19, 2010, 04:52:50 PM »
While on the subject of bike tires/speed ratings..... class record is below 200, but my concern is the H rating for bikes vs. cars. Bikes are limited to 130mph. while cars may run to, I believe 150mph.
It would seem the tire loading would be less for bikes, even though cars have 2 or 4 mounted.
I have/run: 100/90H19 Avon Roadrunners on the front, 200/60VB16 Avon AM23 on the rear. These are tube type tires, with required metal caps. What speed(s) am I good for ?
Thoughts/ideas appreciated...........                    Morph
