. . . In the SCTA rules it states that for unitized construction the support bars shall have a 1/4in thick support pad on top and bottom of the floor (in a sandwich construction).
There is some confusion in the rule book about this. Contact "Kiwi" Steve Davies, chief car inspector. But wait till he has had time to decompress after Bonneville. Let us know what you find out.
Ok just contacted Steve:
Hi Steve,
I am building a Chevy Monza for /BGALT class. The rules state that "on unitized construction and monocque cars, the roll cage structure and braces
shall have 1'4-in thick support pads on the top and bottom of the floor (or sill, in a sandwich construction) ...ect.
My question is... does this "top and bottom" apply to welded cages?
the reason i ask :
I have some rather beefy frame connectors running right up close under the floor and would like to incorporate them into the roll cage equation. I would like to
weld the cage tubes to the frame connectors and pass them up through a support pad on top of the floor, welding that pad and tube to the floor skin.
Thanks
Fred
Reply:
Hi Fred, the top and bottom refers to bolted cages, what you are proposing sounds good, send me some progress photos, (not too large).
Cheers, Steve.
