Author Topic: Need quick-change advise for B/Gas Roadster  (Read 4494 times)
Offline Skip Pipes
  • I hate being bipolar, its awesome!
« on: November 24, 2005, 04:29:48 PM »
Building a new B/Gas Roadster and looking for recommendations on new quick-change rear ends.
Skip Pipes
Skip's Garage
need
« Reply #1 on: November 24, 2005, 06:26:06 PM »
Contact Joe Timney at Deleware chassis he sells the winters QC.
Offline Skip Pipes
« Reply #2 on: November 25, 2005, 05:09:57 PM »
Thanks Geln,
I'll give Joe a call.
Skip Pipes
Skip's Garage
« Reply #3 on: November 25, 2005, 06:01:37 PM »
It looks like they have a new one since I last looked with a 3.08 ring/pinion for B'ville, that's good :D :
http://www.wintersperformance.com/catalogs/03StreetRodRears/09800.htm
I would stay away from the 4.12 circle track ones.
Their index page:
http://www.wintersperformance.com/catalogs/03StreetRodRears/01800.htm
c ya, Sum
Offline John Burk
« Reply #4 on: November 25, 2005, 11:23:46 PM »
Skip
An alternative to using a quick change rear is to use a G-force reverse output 5 speed driving through a Casale V-drive . Casale gears can be changed like a quick change . A Doug Nash , Richmond or G-force 5 speed could be converted to a reverse output with parts from G-force .
gunracer1
« Reply #5 on: December 19, 2005, 11:58:39 AM »
can one of these live with 1400 fpt?
need quick change
« Reply #6 on: December 19, 2005, 12:26:06 PM »
gunracer
What kind of vehicle are planning to run, Gale Banks blew the back half off his in the pickup a couple of years ago. Not sure what MFG it was.
Where are you located
dwarner
« Reply #7 on: December 19, 2005, 01:26:45 PM »
Banks used a Winters QC. Claimed 1100 fpt.
gunracer1
« Reply #8 on: December 19, 2005, 01:59:14 PM »
i live just west of fort worth tx. i talked to winters after i posted on here and he seems to think the heavy duty model made with the 206 alloy will hold up. i think it will be fine for high speed stuff but i also want to drag race it. and he said i could go with 35spline axles. but with a truck weight of 4500 or more i am starting to think it just won't hold up. 20 to 40 psi launches on a set of slicks really has me worried.
« Reply #9 on: December 19, 2005, 03:16:57 PM »
Is an aftermarket Ford 9 inch out of the question?  At least for the drag strip runs?
With a 2.47 gear you can go pretty fast.
c ya, Sum
