im using 3" wide pulleys to joint the engines together on my twin panther
i need to support the outer edge with a bearing of some type. been looking and really cant see much in the way of a simple solution.
was thinking along the lines of a plumber block bearing on the outer primary case with a top hat adapter going into the end of the pulley
just seems kinda crude - and i also need to make sure i can get a plumber block that will run at about 6000rpm happily enough
is there a better more tried and tested solution?
