The tire requirement isn't based on what you think you can run. The requirement is based on the record in each class. If you bump the class record above the rating for the required tire you'll also bump the tire rating requirement for every vehicle in that class.
so since the record that im running against is under 70mph any tire is good? (rules say any motorcycle tire under 70mph)
but my plan is to run more then 70mph and i dont want to run faster then my tires are rated for (i feel thats unsafe)
or can i run 115mph rated tires in the class and take the record and be safe and with in the rules? but then that means the next runs against that time will NEED to run the H rated tires
please understand that im not trying to cheat the rules or run a set up that is unsafe.
my goal is to understand what the rule is and then see how to build to it.
but that being said i dont think it would be right to make the 70-130mph motorcycle guys run H rated tires as i feel that over kill and hard to find in the right sizes
the BT39ss tires would be nice but are RACE tires but not H
