whitehendrix
New folks
Offline
« on: July 24, 2010, 11:11:57 AM » |
hey guys.. have a friend of mine coming to America with a nasty turbo 9R to run loring and he wasn't sure if his valvestem meets the spec.. honestly, neither do i.. tried getting a hold of todd dross, but to no avail as he's a busy man.
heres what he sent me.. any help will be greatly appreciated.I'm ask a question on the valve stems ? My goal is 200 MPH. I have aluminium caps with stock valve and the rule is : 7.B.9 Valve Stems and Caps: All tire valve stems must be fitted with metal valve caps. Over 175 MPH, tubeless tires must use metal valve stems. Tube type tires with rubber valve stems that are angled relative to the rotational plane of the wheel must have those valve stems secured to resist centrifugal force deflection. Safety wire or other approved restraining device is required. My stock rubber valves with aluminium caps are good or not
willieworld
« Reply #1 on: July 24, 2010, 11:19:41 AM » |
if you have a tube yes --if you dont have a tube NO willie buchta
willie-dpombatmir-buchta
dw230
« Reply #2 on: July 24, 2010, 11:21:09 AM » |
I think the rule is pretty clear on the valve cap. No alum.
White Goose Bar - Where LSR is a lifestyle Alcohol - because no good story starts with a salad.
whitehendrix
New folks
Offline
« Reply #3 on: July 24, 2010, 11:29:26 AM » |
tis a tubeless rim/tire.
being (the) aluminum (valvecap) is a metal, thought that was good to go.. lol
i appreciate the input
willieworld
« Reply #4 on: July 24, 2010, 11:30:18 AM » |
dan i will argue the point with you---the rule doesnt say steel it says metal aluminum is metal ---the important thing to this rule is the rubber seal inside the cap --if centrifugal force forces the valve stem needle down with a rubber sealed cap the air wont escape from the tire willie buchta
dw230
« Reply #5 on: July 24, 2010, 11:53:34 AM » |
I give up.
willieworld
« Reply #6 on: July 24, 2010, 12:47:10 PM » |
here is a list of some metals 003 Lithium 004 Beryllium 011 Sodium 012 Magnesium 013 Aluminium 019 Potassium 020 Calcium 022 Titanium 023 Vanadium 024 Chromium 025 Manganese 027 Cobalt 028 Nickel 029 Copper 030 Zinc 033 Arsenic 040 Zirconium 042 Molybdenium 047 Silver 048 Cadmium 051 Antimony 056 Barium 076 Osmium 078 Platinum 080 Mercury 081 Thallium 082 Lead 092 Uranium willie buchta
whitehendrix
New folks
Offline
« Reply #7 on: July 24, 2010, 12:52:51 PM » |
hmm.. did not know calcium was considered a metal.
interesting. wonder what TIG process you use to weld that stuff together..
ol38y
Offline
When all else fails, gas it!
« Reply #8 on: July 24, 2010, 12:59:05 PM » |
Willie, you forgot unobtainium... Sorry, don't know the number..
Larry Cason Bakersfield,CA It's a dry heat!
2010 BUB 1350 M-PG record 2012 Speedweek 1350 A-PG record 169.975 2014 El Mirage Dry Lake 1350 A-PG 172.651
willieworld
« Reply #9 on: July 24, 2010, 01:02:06 PM » |
im thinking the arsenic flagged rod ---i have a box of valve stem caps all metal that i have collected over the years maybe 3 or 4 hundred all of them have the rubber seal inside ---if i run a magnet through them not one cap will stick-----looks like to me if you want steel ones you will probably have to make them yourself---i will bring the box to bonneville -----------------willie buchta it is unobtainable so i didnt put it on the list  the atomic number is somewhere between 113 and 199
« Last Edit: July 24, 2010, 01:08:16 PM by willieworld »
DahMurf
Offline
2006 Hayabusa Mutt
« Reply #10 on: July 24, 2010, 02:05:01 PM » |
If you send Todd an email he'll be happy to respond. ectatech@twinjugsracing.com. He's been on the dyno all day but does his best to check email in the evening & field calls at the shop as much as possible (when he hears the phone ring - it's kind of loud when the dyno is running but we do have an answering machine.). In regards to the question above, if he intends to run over 175mph then yes he needs metal valve stems. I'm not sure I'm clear on what valve stems he currently has. I'm not clear if they are rubber or aluminum. If they are aluminum with the metal o-ringed cap then he's good. If it's rubber it needs changed. A tire change is an annoyance at this point but shouldn't be a show stopper. If he can't source the metal valve stems speak up now. Not sure if we have any but someone might & there's always a next day air option on ordering. Hope this helps. Debbie
whitehendrix
New folks
Offline
« Reply #11 on: July 24, 2010, 08:26:38 PM » |
If you send Todd an email he'll be happy to respond. ectatech@twinjugsracing.com. He's been on the dyno all day but does his best to check email in the evening & field calls at the shop as much as possible (when he hears the phone ring - it's kind of loud when the dyno is running but we do have an answering machine.). In regards to the question above, if he intends to run over 175mph then yes he needs metal valve stems. I'm not sure I'm clear on what valve stems he currently has. I'm not clear if they are rubber or aluminum. If they are aluminum with the metal o-ringed cap then he's good. If it's rubber it needs changed. A tire change is an annoyance at this point but shouldn't be a show stopper. If he can't source the metal valve stems speak up now. Not sure if we have any but someone might & there's always a next day air option on ordering. Hope this helps. Debbie hey debbie!! wish i could make it up there with ya.. this year sucks for me so far.. lol hoping ali is running and does well..
you answered my question then for this guy and i appreciate it. told him chances are todd will be the one teching the bikes anyway.
i can't remember what country this guy is in, but it'd be a shame for him to miss out for a small part! i told him about loring last year and i am pretty sure he's planned this trip and run since i told him.
miss ya guys. hoping the turbo motor and bike in total will be done and operative THIS time next year so i can come play.
best of luck, deb!
thanks again, willie.
-Jim
