Author Topic: Belly Tank Lakester  (Read 72792 times)
Offline dshuken
    • Shuken Racing Fabrication
Re: Belly Tank Lakester
« Reply #60 on: October 13, 2010, 12:42:45 AM »
Mike,
I usually set front hoops at 20-25 degrees from vertical. (NHRA mandates no less than 20)  I think this one ended up at 22.
Hope that helps
Daniel
Offline Fordrat31
« Reply #61 on: October 15, 2010, 02:29:14 AM »
Yes it does! Thank you very much.
Speed, you have to make it your friend, then convince it to volunteer on you team
Offline racergeo
« Reply #62 on: October 17, 2010, 08:47:40 PM »
   You might want to contact someone from tech about that angle. I know I bought a project that was started back in the early 90's and tech told me the front hoop had to be at least 30 deg.  You can get a deviation request . When you look in your rule book it depicts a example of what they are looking for.  Better to be safe then.......
Offline Buickguy3
« Reply #63 on: October 23, 2010, 07:28:39 AM »
  Thought the belly tank guys would like this link. Really cool picture. Maybe somebody should copy the photo and put it on Land Racing.
  Doug
       http://www.jalopyjournal.com/forum/showthread.php?t=524065 :cheers:
                   [America]
