May 23, 2013, 06:54:46 AM *
Pages: 1 ... 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 ... 118   Go Down
Author Topic: XXO/BVGC '38 Chevy Coupe Build  (Read 135963 times)
maguromic
« Reply #885 on: February 21, 2012, 12:01:23 AM »
Hard to believe - but Tony, I've finally seen something sexier than your avatars on these boards.
Buddy, Dale - That's ONE BEAUTIFUL ENGINE!
Like I said, it makes my man parts tingle.  You guys have built some serious  EYE CANDY. Tony
Jack Gifford
« Reply #886 on: February 21, 2012, 12:42:23 AM »
Thanks for the two-piece head education. Wow... somebody's better with a manual mill than I am! grin grin
The snout support will undoubtedly help. With some foresight (or glancing at well-engineered ones) though, it could help much more; not much rigidity to a "plate on pillars". Just my two cents...
« Last Edit: February 21, 2012, 12:44:51 AM by Pontiac Jack » Logged
M/T Pontiac hemi guru
Dr Goggles
« Reply #887 on: February 21, 2012, 12:45:07 AM »
We can swap the lower-upper pulleys and switch over to a 48 driving 53 pulley setup, but if we want to run a larger upper pulley during breakin, we'll need a longer belt.
Longer belt?......... what are ya gonna get , a conveyor belt?
Koncretekid
« Reply #888 on: February 21, 2012, 06:56:08 AM »
You took the words right out of my mouth regarding the rigidity of the "plate on pillars."  You could stiffen it up by replacing the "pillars" with a rigid rectangular plate on each side with three holes for the bolts.
Regarding the rest of the build, it showpieces the talent and dedication of the members of your team.  You are to be congratulated.  Of course it has caught my attention from the very beginning, because my first car was a '37 Chevy with a '57 Pontiac motor.
« Last Edit: February 21, 2012, 07:00:30 AM by Koncretekid » Logged
38flattie
« Reply #889 on: February 21, 2012, 08:00:47 AM »
It's hard for me to argue the point. I'm not fond of it in the first place-I think it looks like a spider humping the crankshaft!
Still, we felt we needed it, and I think it will do the job.
It's an off the shelf piece from Fowler Engines, for BBC's. If it appears to be letting the crankshaft move, we can plate between the 'pillars', or make a stiffer one.
The engine is very tall, but sits so low in the car, it doesn't appear as tall when installed.
« Last Edit: February 21, 2012, 09:29:16 AM by 38flattie » Logged
http://www.facebook.com/FlatCadRacing
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Only time and money prevent completion!
« Reply #890 on: February 21, 2012, 11:09:20 AM »
Buddy,
That thing is a beast!!! Pretty, but a real beast. If it runs half as good as it looks you will make tons of HORSE POWER!!
Tman
« Reply #891 on: February 21, 2012, 12:39:42 PM »
One of those people movers from the airport!
www.compulsionrodandcustom.com
Hotrod, racing and performance parts
38flattie
« Reply #892 on: February 21, 2012, 12:52:49 PM »
Longer belt?......... what are ya gonna get , a conveyor belt?[/quote]
[/quote]One of those people movers from the airport![/quote]
Escalator belt? Lol!
Buddy,
We'll see in three weeks if it qualifies as a race engine. If not, I'll see if anyone needs a trailer queen engine! evil
4-barrel Mike
Any fool can drive a V8
« Reply #893 on: February 21, 2012, 03:33:06 PM »
Sweet engine!  Now, if you could find a vintage Cadillac roadster to put it in!   afro
Jack Gifford
« Reply #894 on: February 22, 2012, 12:12:33 AM »
... replacing the "pillars" with a rigid rectangular plate on each side...
Lateral stiffness is nearly as important as vertical. There appears to be enough elbow-room to enhance both.
jl222
« Reply #895 on: February 22, 2012, 03:33:38 PM »
  Great looking engine and work,can't wait to see and hear it at Bville.
  Is part of the breakin for the cam and solid lifters? there should be little or no boost at a steady rpm untill
you put a load on egine or blip the throttle.
zenndog
« Reply #896 on: February 22, 2012, 03:43:13 PM »
That engine is impressive looking. Tower of power.
38flattie
« Reply #897 on: February 22, 2012, 07:36:33 PM »
Yes, I want to get the cam and lifters broke in good, before we add too much load.
BoredAndStroked
« Reply #898 on: February 23, 2012, 10:35:41 PM »
Thursday Evening Update: Magical Mushrooms . . . Psychedelic Man
I've just finished the work on the 'magical mushroom' lifters. We've replaced the stock hydraulic mushroom lifters with some flathead Chrysler mushroom lifters. I got the idea from Barney Navarro about 25 years ago - to put them in flathead Fords . . . but they actually work really nice in the FlatCad. The bigger the lifter base diameter, the faster the cam opening ramp can be (which is good on a flathead - no rocker arms to multiply anything!).
1) The length is just about perfect.
2) The body diameter is smaller than the FlatCad valve lifter blocks, so Buddy had the lifter blocks bronze bushed for me.
3) We have about .0015 clearance
The cam pattern was designed for a 1.260 lifter diameter, so I had to turn the bases of all of them down on the lathe - about .023 reduction in the diameter. As you can imagine, they're harder than hell, but good ole' carbide was able to cut them . . . just took a long time.
We have 20 lifters (4 spares) . . . glad this job is over . . . boring as all hell.
Tomorrow I'll be fitting the lifter blocks, lifter block girdle supports and hopefully finishing the valves by sometime Saturday.
Chris is coming over on Sunday to help with the plumbing - probably while I'm working on the dry-sump mount (which is a real PITA).
Here are the lifters . . .
Member of FlatCad Racing Team - 2011, 2012
Goal:  Have fun, make friends, be safe - learn as much as possible, contribute when I can and hopefully get in the books!
BoredAndStroked
« Reply #899 on: February 23, 2012, 10:43:20 PM »
I like that quote  - 'The Tower of Power' . . .  we can only hope!
Pages: 1 ... 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 ... 118   Go Up
Google visited last this page April 27, 2013, 07:04:34 PM
