Author Topic: XXO/BVGC '38 Chevy Coupe Build  (Read 1031256 times)
Re: XXO/BVGC '38 Chevy Coupe Build
« Reply #1935 on: July 30, 2013, 12:04:20 AM »
Glad to hear you'll do some dyno work before you make the trip down the salt, especially given the huge number of changes that have occurred.
Having been through the embarrassment of running an untested engine, I think you'll be miles ahead of the game.
Get it close - don't throw it away in the bullpen.
Gosh, Buddy - I'll see you next week!  :cheers:
« Reply #1936 on: July 30, 2013, 12:06:59 AM »
Have turbos that can travel!!!!!!!!!  lol
« Reply #1937 on: July 30, 2013, 11:08:24 AM »
Ya but can you keep it under 1000 RWHP  :cheers:
« Reply #1938 on: July 30, 2013, 12:28:34 PM »
The two small S400s will ---down side T6 flange--upside small compressors large turbines
Offline 38flattie
« Reply #1939 on: July 30, 2013, 05:10:20 PM »
Funny you should say that Sparky-I've been looking at a pair, with T4 flanges! :-D
http://www.ebay.com/itm/Borg-Warner-S471-100-AR-Twin-Scroll-T4-Turbo-S400-/221259665076#ht_576wt_899
http://youtu.be/89rVb497_4c
« Reply #1940 on: July 30, 2013, 06:48:48 PM »
What size are all of the wheels that will tell what they are.
Compressor         Inducer          Exducer
Turbine               Inducer          Exducer
Offline 38flattie
« Reply #1941 on: July 30, 2013, 07:20:10 PM »
Here is what I know:
Compressor wheel - 71.06mm/101.45mm 95lbs/min
Turbine wheel - 77.5mm/87mm
Compressor inlet - 5" hose Ported Shroud
Compressor outlet - 4" v-band
Turbine Inlet - Divided T4 1.00 A/R
Turbne outlet for 4" v-band
capable of supporting 1000hp+
Offline pops29
« Reply #1942 on: August 03, 2013, 06:23:48 PM »
 Hi Guys here is an up-date on the Dyno
Well it has been a rough start #1 Dales Friday night flight was canceled , he had to get a flight out this morning and arrived at 10, # 2 the airline lost all his luggage, including the Mags and all the wiring setups , after 5 hours they got a call the luggage was on its way !!! So Right now they are finally starting to put the car together to fire up late tonight and if all is good start the tune in the morning. So Keep your fingers crossed we have no more set backs
__________________
www.laserartworld.com
Offline pops29
« Reply #1943 on: August 04, 2013, 06:42:17 PM »
OK------  Dyno Complete
 The numbers on Gas were good to last years numbers,, Alky was a fight,,  all the runs we too fat and no jets small enough to make any good runs. We will be getting some new jets overnight ed to me and will as Per John Beck  do some leaning with Nytro !!   Buddy and Randy are packing and Headed back to Randys to work on the clutch issues,, not enough throw to disengage,,,,  SEE YOU ON THE SALT !!!!!!!!
« Last Edit: August 04, 2013, 06:59:56 PM by pops29 »
« Reply #1944 on: August 04, 2013, 06:47:02 PM »
« Reply #1945 on: August 04, 2013, 09:14:24 PM »
Now that's an interesting approach - just keep blending fuel until it matches the jets.  :-D
Offline Pete1
« Reply #1946 on: August 04, 2013, 09:34:11 PM »
Done that many times.
« Reply #1947 on: August 04, 2013, 10:14:55 PM »
Pete, I forget. Are you gonna be there? Wayno
Offline Pete1
« Reply #1948 on: August 05, 2013, 12:58:13 AM »
Nope. Maybe October.
Offline Jack Gifford
« Reply #1949 on: August 05, 2013, 01:19:10 AM »
... no jets small enough...
That's  an unusual-sounding statement for blown-alky. Old-school constant-flow? Can't just keep going larger with the bypass pill?
M/T Pontiac hemi guru
