Author Topic: XXO/BVGC '38 Chevy Coupe Build  (Read 1031373 times)
Offline 38flattie
Re: XXO/BVGC '38 Chevy Coupe Build
« Reply #1740 on: May 21, 2013, 05:47:06 AM »
Jack, you're right.
We didn't have dowels last year, but we had tight head bolt clearances, assuring us of precise positioning. Installing/removing heads with tight head bolt tolerances is an extreme PIA, and time consuming. We added the dowels, and opened up the head bolt tolerances slightly, to insure we still had the needed alignment, and to make installation and removal easier.
http://youtu.be/89rVb497_4c
« Reply #1741 on: May 21, 2013, 10:15:18 AM »
Jack, you're right.
Yeah, flatty heads can be a pain even with loose tolerances to pull.
Offline 38flattie
« Reply #1742 on: May 21, 2013, 07:02:22 PM »
John K.(WZ JUNK) Has been slaving away! From John:
Front aero is done except for the black plastic on the bottom.
I will work on the flange for the hood sides and the grille area tomorrow.  This is nearly last area of fabrication.  The fit around the grille will be the last big thing.  It is all down hill now.
Looking good, John!
Offline vintagehotrod
« Reply #1743 on: May 22, 2013, 09:54:22 PM »
Buddy , you are out of control , what an amazing effort. I will do my best for you on dyno day. I would hate to be the guy that sinks this ship. You are doing everything right , cyl pressure will double from straight alky to just 20% with a blower. We will feed it right , plenty of fuel.
Offline 38flattie
« Reply #1744 on: May 23, 2013, 09:19:42 AM »
John, I'm really looking forward to the trek to Chico!
I learned a lot last year, and look forward to your help and mentoring again this year.
And again, a BIG thanks to Stan Back for directing me to you-he was right, in saying you were the man we needed to help us! :cheers:
« Last Edit: May 23, 2013, 09:25:57 AM by 38flattie »
Offline 38flattie
« Reply #1745 on: May 23, 2013, 12:50:40 PM »
John has been busting his hump!
From John:
What the starter at the starting line will see.
I will work on the fit around the grille opening and the front seam where the two fenders meet next.
Offline redhotracing
« Reply #1746 on: May 23, 2013, 01:35:57 PM »
Buddy- maybe I missed this, but how much whp
are you looking for with 20% nitro? How much are
you estimating to need to reach your goal of 200?
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Offline 38flattie
« Reply #1747 on: May 23, 2013, 01:58:42 PM »
Well, all things being equal, I think we need about 800. John and Sumner think I probably need more.
Now, that would be running exactly as before, with no changes. I'm hoping aero, along with a full bellypan, will allow us to run with less HP, because I think we'll struggle to get 800 on the dyno, and have the engine survive, let alone get that much to the ground.
We had problems getting the HP to the ground, and really saw little gains after the low 160's.I think the car was floating in the rear, so I have high hopes for the bellypan. Last year, the bellypan only covered the front 60% of the car.
I have no idea if all of this will get us the results we need, but if we fall short of our goals, it sure won't be for lack of trying!
« Reply #1748 on: May 23, 2013, 03:05:00 PM »
It looks extremely mean! :cheers:
Offline Koncretekid
« Reply #1749 on: May 23, 2013, 06:51:45 PM »
Buddy,
I think aero is going to achieve a lot more than you think.  I would be cautious with the increase in HP until you see how much you gain with the body changes.  There's always next year -- if you don't blow the motor.
Offline Pete1
« Reply #1750 on: May 23, 2013, 07:07:44 PM »
Buddy,
You guys talk like a bunch of dimwits...You build them to race, not to idle around and save it for next year.
If you build them right they don't blow.
« Reply #1751 on: May 23, 2013, 07:16:01 PM »
Well whoop te do---I guess that explains my problem--let's see-- I dim witted--- for I blew up several--that means they were not RIGHT ---dumb me I thought they  didn't like 7900 for the last mile!!!!
Offline Pete1
« Reply #1752 on: May 23, 2013, 07:28:41 PM »
You can't go past the valve train for very long.
Offline 38flattie
« Reply #1753 on: May 23, 2013, 07:31:51 PM »
Well,dim witted or not, I believe every engine will only withstand so many RPM's, and so much cylinder pressure. Then, BOOM!
I think Tom's advice of being cautious with our HP increases, and seeing how much more we may need on the salt, is a helluva lot better than just adding HP until we think we have enough, then BOOM! Kitty litter time!
Pete, you've been building engines and racing a long time-I'll bet you've blown up your share of engines, correct?
Sparky, I'm sure you're dim witted-we all must be! I really can't think of a better explanation for what we are all doing here! LMAO!
Offline RichFox
« Reply #1754 on: May 23, 2013, 07:35:28 PM »
Buddy,
LOL. Tell us how you really feel.
