Author Topic: XXO/BVGC '38 Chevy Coupe Build  (Read 1029386 times)
Offline Roseville Carl
Re: XXO/BVGC '38 Chevy Coupe Build
« Reply #1650 on: April 01, 2013, 12:17:07 PM »
Hell and I thought you were gonna give the Flat Cad to me to put in the dragster!!
"Keep Em Between the Whites"
and yes Virginia the world is indeed Flat
Offline Captthundarr
  • In line
« Reply #1651 on: April 01, 2013, 12:26:07 PM »
Dag..... I had my check book out and ready :-(
Offline 38flattie
« Reply #1652 on: April 01, 2013, 01:32:13 PM »
Sorry guys-try me in late August! :-D
We need some unknown material for the fiberglass front end John K. is building. Hopefully, someone will know what it is we're looking for! Lol!
From John:  I need to find the product to use for the skirting material at the bottom of the body panels.  I need some of the black stuff that you have seen on other cars.  Probably about 3 inches wide maybe 2” would do,  and 3/16” to 1/4” thick.  Do you have any ideas?  I think they use a plastic material but maybe some stiff rubber would work.  I would like to know what works.  I know the front piece has to be stiff enough that the air would not blow it back but I would like it to have some flex in case or when it hits the salt.  It will be riveted to the bottom of the panels.
http://youtu.be/89rVb497_4c
« Reply #1653 on: April 01, 2013, 02:03:16 PM »
Circle track stuff, the plastic used for body parts.
« Reply #1654 on: April 01, 2013, 03:35:49 PM »
Contact fivestarbodies.com. They should be able to help.
« Reply #1655 on: April 01, 2013, 03:37:50 PM »
Offline GH
« Reply #1656 on: April 01, 2013, 10:15:37 PM »
John, how about UHMW, it's like Teflon except it is a lot harder and stiffer. That's what these newer over head cam engines use for the wear strip at the chains.
« Reply #1657 on: April 02, 2013, 03:24:07 AM »
Polypropylene, well I think that's how it's spelled. I used it as skirt material on my race car in the 80s when we still ran wing cars. Rivets will require large heads or washers.
Offline 38flattie
« Reply #1658 on: April 03, 2013, 12:55:13 PM »
Fordboy, you're right on at least some of your summations.
We did find that the flow increased by 'lengthening' the short side radius. Different valves helped, but ONLY after addressing the short side radius. The stock heads, and modified stock heads, flowed better than the race heads.
There will be a lot of work done in this area next winter, when we switch to turbos!
John K has been working feverishly on the front aero mods. Randy and John set and checked the alignment last weekend.
John is getting closer on the fiberglass work. He says the is still a slight difference side to side, but he's gaining on it!
Nice work, too! Way to go, John!
gkabbt
« Reply #1659 on: April 03, 2013, 04:19:42 PM »
Guys,
Keep up the GREAT work!
This is such a cool pic!
Offline 38flattie
« Reply #1660 on: April 03, 2013, 04:43:25 PM »
HELP! I need a m7 x .8 Tap!
Don is working like crazy to get the lifters done. We are using early Harley adjustors, and just found out the take a m7 x .8 Tap!
If anyone has one they are willing to sell, or knows where I can get one ASAP, it would be much appreciated!
« Reply #1661 on: April 03, 2013, 05:04:21 PM »
You sure that is right? I can not find that size anywhere.
Offline 38flattie
« Reply #1662 on: April 03, 2013, 05:09:06 PM »
Yep, it's right. I'm guessing Harley used that size to discourage everyone making copies of their work!
Offline saltwheels262
  • LTA 7/2013
« Reply #1663 on: April 03, 2013, 08:03:37 PM »
the only bastard size thread that I can think of for a Harley
would be 1/4-24 .
it was used for securing lifter blocks to the engine case
and on ( I think ) oil pump studs to the engine case.
also, maybe more apps to the engine .
8 2nite .
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
« Reply #1664 on: April 03, 2013, 09:38:10 PM »
would be 1/4-24 .
1/4-24???????????? Sounds like they couldn't decide on a 1/4-20 or a 1/4-24 so they took the average between the two. I've never encountered a 1/4-24.
