38flattie, bored&stroked,
Are there any clear close-up photos of the oil drillings in the crankshaft you can post up? What I want to see is the 'phasing' of the oil flow with respect to each cylinder's individual TDC. How the delivery of the oil supply is 'phased' determines if you must run relatively high pressure or if you are able to run relatively low pressure.
In "low pressure" cranks, the oil delivery hole for a particular con-rod/cylinder, is 'phased' to 'lead' TDC by 50/60 crank degrees. This allows the oil film to be 'distributed' onto the crankpin prior to the highest load period, (20/25 degrees BTDC to 50/60 degrees ATDC) during the ignition & combustion phases. There are SAE papers about this subject, although I have not read them in a while. Oil delivery to the con-rod bearings, with crankpins drilled @ either TDC or 90 degrees BTDC, was judged to be less effective,
at lower pressures. Keith Duckworth came to the same conclusion. There have been some other technical articles on this subject over the years penned by, I think, Smokey Yunick & Bill Jenkins. So the bottom line is: how the crank is drilled dictates how much oil pressure you have to run.
If you guys ever have to order a replacement crank or build up another complete engine, you may want to consider this effect.
