Author Topic: few questions about running in the mod motorcycle class  (Read 3583 times)
Offline jaguarsurfer
« on: July 08, 2010, 10:03:28 AM »
hello
im looking to build and run my first bike with the ECTA.  i have this years rule book and have read the motorcycle class parts.
im looking to run in the modified class with a honda CB125 but have a few questions
-as long as im using a stock frame can i add bracing to the rear of it?  all would just be bars on the inside under the seat.  these would not change wheelbase or suspension geometry.
-can i change the front forks to something off of a bigger honda motorcycle?
-i can run "clip on" bars as long as they are taller then the wheels?
i know that they might sound like dumb questions
i have built a few cafe racers and would love to build a small bike to run at ecta and maybe one day on the salts but want to do it the right way the first  time
thanks so much for any help
Offline nrhs sales
Re: few questions about running in the mod motorcycle class
« Reply #1 on: July 08, 2010, 11:07:00 AM »
Should have no problems with the frame changes you mentioned for modified class.
« Reply #2 on: July 08, 2010, 01:13:23 PM »
things like removing unused tabs and stuff is also ok?
i guess that falls under modifing for racing but wanted to know at what point you have to stop before it changes class
can you cut off the rear of the frame that is not used?
Offline 55chevr
« Reply #3 on: July 08, 2010, 09:55:22 PM »
Do you have a rule book?
« Reply #4 on: July 09, 2010, 12:44:00 PM »
yes i do.
so if the rule book says that you cant then i can right?
its the first time im building something to a class so thats why i have so many odd questions
*where on long island are you?
im in bay shore
Offline willieworld
« Reply #5 on: July 09, 2010, 01:47:54 PM »
acording to the ecta rulebook you can change forks and wheels  7.F and 7.F.7--  yes you can modify the frame as long as it retains the stock geometry  7.F ( line 7 )  yes you can use clip on bars  7.F ( line 12 ) -----------  hope that helps                    willie buchta
willie-dpombatmir-buchta
Offline John Noonan
« Reply #6 on: July 10, 2010, 01:39:56 AM »
Willie are you coming out to El Mo..?
Nice weather and hoping the course is moved back a few hundred feet so we have a better run up for a better top speed..
See you here.
« Reply #7 on: July 15, 2010, 01:20:29 PM »
and as i understand it i can change the tank to anything else as long as its more then 5L and stay in the mod class right?
thanks again for all the help.
i know that they might sound like bad questions but im trying to learn and do things right the first time
« Reply #8 on: July 15, 2010, 01:24:11 PM »
As long as the replacement tank has a capacity of more than 5 liters it's okay for Modified class.  You might, for instance, elect to change the shape of the stock tank to allow the rider to get into a better tuck.  That's common.  Another way that's been tried to circumvent the maximum of 5L rule is to "stuff" the more-than-5L tank with something -- maybe an inner tube, for instance -- and have the resulting capacity be less than 5L.  It's a lame way to do it and is highly frowned upon -- to the point that you might just have a difficult time getting through inspection that way.
Offline nrhs sales
« Reply #9 on: July 15, 2010, 01:29:47 PM »
Slim,
The rule is a minimum of 5 liters not a maximum. I believe your thinking is backwards.
