been doing some reading [always dangerous] and have come across something that might be a problem for me - not a big one just finding another carb
im running an eaton m45 on my twin panther [when its done] order of play will be
carb through blower [sucker in this case] into engine
now i was reading that on an su type carb the slide can get cocked round in the body and stick wide open from the force of the blower - is this just a wives tale, or if you are running masses of boost or something - im not looking at running all that much...
i see the logic but havent found any hard facts yet.
just working out before i spend my sheckles on rebuilding this carb if its potentially an issue
anyone done it or had problems / success etc?
LOTS and LOTS of the old European blown drag racers used SU,
and the blower/SU set-up is the standard set up for all the MG TD/TC racing boys.
Recently at the Copenhagen Classic Grand Prix I came
across these and more:
To be safe you'll need a thing like this on my carb
...a dual-cable-gas handle / two cables / a "wheel" or "rotor" on the butterfly shaft so that you can force it closed
should (what you call the 'slide' or) the vacuum piston and butterfly stick
in the open position.
It's the standard set up on the American Primo-Rivera SU carbs ,
basically Brit Burleen SU's modified for Harley use.
Check this Pdf
DUAL CABLE ROTOR AND BRACKET(scroll down a bit.)
Actually I'd say it's an advantage to run a set-up like this as you can force it closed.
Let's say you were running a flat-slide MIKUNI or something similar,
there would be no way to force closed a sticking slide.
