deb could you move from the sidecar class to the streamline sidecar class and then to the streamliner class thanks willie buchta
Only if you make the necessary body changes.
In order to run in the streamliner motorcycle classes, with or without the sidecar, you must adhear to the roll cage, firewall, fire suit.... rules.
So, if you build a big fancy cage you could slide your rig into and bolt/weld it all on per the rules you probably could do it but that's a heck of a lot of work!
A traditional motorcycle with or without a sidecar is not allowed to just "run up" without change into the streamliner classes.
(we'd love to have you run on our turf & set up our baseline records in those open classes! The sooner we fill up the classes the sooner we can have a "true" points chase!
As it stands now we're up to almost half our top ten finals in points being achieved only on existing records! I haven't checked the status for this year yet!)
