i would rather have 1 record that stood for 20 years as to have 100 records that were to fall next year---at el mirage if you are racing for the points championship you have to run in the same frame class all year and you cant change engine classes at a single race--1 race 1 class ---there no open records --if no one has set the record then there will be a minimum ---points are for your fastest run of the meet---if you run under the record ( or minimum ) the run is divided by the record then multiplied by 200 ( run 123 record 126 = .9761 X 200 =195 points---if you break the record ( or minimum ) you get 200 points + 25 + 1 point for every full mph over the record---also we compete for starting line position --the person with the most points runs first at the next meet --and club points ( 12 clubs competing ) there is much more but i got to get back to work willie buchta
thanks dan you saved my typing finger
Good points Willie. Let me add that comparing the points system (Elmo and Maxton), championships (Elmo and Maxton), records for open classes (Maxton and Bonneville) is an interesting exercise but that does not imply that one is better, worse or whatever. There are good reasons for the differences. You have pointed them out. El Mirage has competition for starting positions. Maxton does not. At Maxton it really is no advantage to have a start position and run earlier in the meet. The conditions of the racing surface are virtually identical for all runs. (concrete being more durable than dirt). And . . as you said, El Mirage has club points championships. Maxton does not.
One plus to ECTA allowing us to run-up in class is that after a record is set in what was previously an open class it has somewhat the same impact as there being a class minimum. Example in point . . . When I set my ECTA record in an open class (H/BFSS) at 126 mph I got 352 points. (100 for setting the record plus 2 for each mph over the old record (126 - 0 = 126) Consider what would have happened if, the year before, the recordholder in the next lower class (I/BFSS - 118) had decided after setting the I class record to change classes and run in H/BFSS. If he had run 118 mph he would have set the H/BFSS record at 118. Then I come along the next year and run 126. Yes I do get the record, but I only get 116 points. (100 for the record and 2 for each mph over the old record (126 - 118 = 8 )
That other racer, by running up in class, effectively set a 'new minimum' for H/BFSS. So you could argue that (in a way) running up in class helps to level the playing field for the points chase. Of course this only works when the vast majority of open records have already been picked off. . . . . In the mean time there are opportunities for someone willing to 'game the system' to really rack up a ton of points in one year.
imagine if someone showed up the first meet at maxton next year with a real honest to goodness top quality A/Gas Streamliner (open record) and for the five events that year run A/GS in March, A/BGS in April, A/BFS in June, AA/GS in September and AA/BGS in October. (all open record classes) If they run 250mph each event, that is 600 points per meet (100 for the record and 2 for each mph over the record (500) for 600 per meet and 3000 for the season.) The highest total car points for the previous five seasons at Maxton never exceeded 2000. In the streamliner example they could take the championship runnin only 4 events and maybe only 3 events. (that leaves more open records for the next season)
Not good or bad, . . just how it is.
