Hi everybody,
I'm new on this forum and i start a new thread, because it's the first time i will go to Loring for race. I never race at mile mark event before and i prepare my bike for pass the tech inspection for break 200 mph at the event to Loring. I read the rules, but i have some questions on some rules ?
First my bike is a street bike, it's Kawasaki ZX9R Turbo 00. I built my turbo kit and tuned my self. I ran on the street with this set up since 4 years.
My set up is :
Motor #1 : J.E Forged Turbo pistons 8:1
Motor #2 : Stock and lower compression with space plate
Turbo kit is built my self
Turbo : Little Mitsubishi
Intercooler air to air
Water injection system too (50/50 water and methanol)
Bolt on extended swingarm +6 in.
I would like to know what is my race class ?
Frame class : M : Modified Production ( extended +6 in = 62 inches) Right
Engine class : BG : Turbo motor with gasoline and water injection system allowed.
I would like to know if water injection system allowed is water only or 50/50 water
and methanol
Engine displacement class : 1000cc : my bike is 899cc ( no 900cc class
) Right
Also, the rule of the batteries is :
7.B.26 Batteries:
All batteries shall be properly secured with metal hold downs, framework and fasteners. Plastic tie-downs are not allowed. OEM battery hold-downs may not be adequate.
On my bike I don't have strap for secured my battery. My OEM factory lock setup on my bike, it's my seat locked my battery. Do i need to strap my battery
Questions on secure the bolts and parts :
The front wheel shaft is lock by two bolts on each side ( OEM factory). Do i need to secure the bolts with a wire
The oil bolt for flush the motor oil, wired too
Need some modifications to the oil filter. My filter is relocated.
Thank you to everybody will help me.
