Author Topic: Jr Dragster front wheels?  (Read 4645 times)
Offline SlyOneJr
« on: June 22, 2010, 04:28:23 PM »
Saw a post earlier on here about running the Jr Dragster wheels on a sidecar, and I was wondering if you could get a tire that says "FOR RACING ONLY" on the sidewall if these would be legal for a K/GL that is going at most 130 mph? Figuring a car weight of 800 to 850 lbs with driver, for Maxton only. Either that, if they are not legal, anyone have a set of dragster spindles for cheap?
Jeff
New Guy building a L/Gas Lakester
Ninja 250 powered Lakester for ECTA meets
Offline sheribuchta
Re: Jr Dragster front wheels?
« Reply #1 on: June 22, 2010, 07:49:37 PM »
jeff  what size wheel and tire do you want to run and in what class ( what speed )   willie buchta
Offline SlyOneJr
« Reply #2 on: June 22, 2010, 09:27:40 PM »
Looking at the 16" wheel and tire setup for the front of the Jr Dragsters, putting together a K/GL for Maxton, hoping for a strong tailwind to get me to 130.
Offline sheribuchta
« Reply #3 on: June 22, 2010, 10:17:08 PM »
sorry i saw  sidecar in your first post and quit reading---you are talking of building a car  (lakester) with a K engine 30 cu in  ---i was going to build a streamliner with a 500 cc (30 cu in ) motor and after pricing the safety equipment required about 4000 dollars i decided to stick with the bike--buy a rule book and read it very carefully 10 times--welcome to lsr amd landracing.com   willie buchta
Offline dw230
« Reply #4 on: June 22, 2010, 11:25:08 PM »
I see you plan on Maxton for your build. If there is any chance in the future you will run the salt you will have to re-think your tire plan. The record is around 175, certaintly closer to 200 after this year.
