Gee Mr D, you had me fooled there for a minute, until I went to the facts as found in the '05 rulebook.
You stated, "Next you will want to lock in records, regulate boost, % of nitro & bump a Vincent from push rod class."
Really Mr D, it sure doesn't appear so in the rulebook.
No where in the section 7 motorcycle rules,and I looked from stem to stern, do the rules limit boost or percent of nitro. Nowhere. Hopefully you will enlighten us with your knowledge?
As far as Vincents go, there are currently four Bonneville records held by Vincents.
MVG 1000cc set in '96
PPG 1000cc set in '00
MF 2000cc set in '88
MPSF2000cc set in '88
Perhaps you could educate us as to the stories surrounding the three records that aren't push rod. Just the facts please.
I'll ask again, why "target" one bike and one racer to change his records after the fact, especially since they were set under the rules of the day?
"Lock in the records" Well now that you mention it, I'm all for that.
I think any record set should be recognized and not legislated out of existence or until it is superseded on the salt. Perhaps SCTA should consider using an * like Baseball did for Maris's record. You know, record set with more games played than Babe. Now that will open up a can of worms!
