Author Topic: What are specs for a seat back brace?  (Read 4203 times)
Offline tedgram
« on: June 18, 2010, 09:05:41 PM »
 My seat back is three inches from the shoulder bar. Can I use 2 or 3 inch wide aluminum strapping? What square area on the seat back? Can the shoulder bar be drilled and tapped to hold the brace or should I use muffler clamps?
« Last Edit: June 18, 2010, 09:07:32 PM by tedgram »
Offline Cajun Kid
Re: What are specs for a seat back brace?
« Reply #1 on: June 18, 2010, 10:51:42 PM »
We have never drilled any parts of the cage tubing,,, what we do is weld on tabs and bolt thru the tabs.
Muffler Clamps for a seat brace ?  Hmm I would not think so...but you need an answer from someone in Tech.
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Offline tedgram
« Reply #2 on: June 19, 2010, 05:52:14 PM »
  That gives me new insite on the bar side. How big a pad should I have where it bolts to the seat? Have you ever seen an I/O port seat back brace? Looks like that uses muffler clamps around the shoulder bar to hold the adjustable brace. I know I can fabricate my own for a lot less than $89 + shipping.
Charles
« Last Edit: June 19, 2010, 06:02:06 PM by tedgram »
Offline Cajun Kid
« Reply #3 on: June 19, 2010, 10:44:10 PM »
Charles
The Auto Power and the I O Port set uos are nice and even for $90   not a bad price, but you could make something just as strong and functional for less than $30 if you have a welder....
The Pad needs to be as wide as the flat part of the seat.. Mine is  about 12" wide.  If you are going to make a tube and plate/pad setup, I would think a 3 x 8 pad would be OK as a Minimun,, I would prefer a 3" x 10" pad if it will fit your seat back,, don't want the brace to spear through the seat back. I would also us at least 3/16 to 1/4 plate and bend a 90 degree lip to provide more strength.
Just my thoughts...
Good Luck
Charles
OHIO
B/CGALT, C/CGALT
« Reply #4 on: June 20, 2010, 01:06:19 AM »
I never use a tube pointing fore and aft, ie. into the driver's back. It is too rigid and can act as a spear, easily displacing or breaking a vertebrae. Use a flat plate and put a double break in it so that there is some give in the case of rear impact to absorb energy. Attach that to the shoulder bar on the cage and to a plate on the back of the seat at the other end. The plate should be substantial enough that it can dissipate some of the energy.
Offline tedgram
« Reply #5 on: June 20, 2010, 10:10:14 AM »
  Thanks for the input guys your are a big help.
Offline Cajun Kid
« Reply #6 on: June 20, 2010, 10:10:52 AM »
PJ,,, that is how we do it too,,,,
I will try to find a pic for Ted
OHIO
B/CGALT, C/CGALT
Offline Cajun Kid
« Reply #7 on: June 20, 2010, 10:38:21 AM »
Here is a pic of my seat back brace. It is bolted to the seat with FOUR  3/8 Grade 8 bolts.
The flat plate goes over the roll cage back/shoulder bar, is trimmed to fit and is bolted to 12" wide cage tab with THREE  more Grade 8 bolts. (I will try to find a better pic of that)
Charles
OHIO
B/CGALT, C/CGALT
« Reply #8 on: June 20, 2010, 10:45:59 AM »
Cajun.........absolutely marvelous.
Quality is evident.
