When you consider where to build your air inlet, keep in mind that the farther it has to travel, the less efficient the design is. If you use the nose, you will more than likely be tunneling the air close to 10 feet to get to the engine. That distance will cause turbulence and therefore flow loss within the ducting reducing efficiency.
Try to get your air in as close to the engine as possible to increase efficiency. Keep in mind that at the higher velocities, you can ram quite a bit of air into a scoop. In some engine applications, you will need to slow the air down before it hits the engine.
What type of engine are you thinking of building? (NA, Boosted, Turbo, Blown, Fuel, gas...)
