Author Topic: Using a wet nitrous setup on EFI  (Read 3360 times)
Offline oz
  • Geordie Power.
« on: May 13, 2010, 03:24:18 PM »
I am starting the conversion from carbs to EFI on the CBR and was thinking that I mght leave the exsisting nitrous system wet.
My thinking goes a bit like this.
All the parts are there already and working and even though the Wide Band O2 sensor should correct the mixture when the nitrous is in use the less it has to alter anything the better as it dosent take long to cause major damage, The mixture on the nitrous can be adjusted to be right proportions prior to running and just leave the ECU to fine tweak in use.
Any thoughts or draw backs in doing it this way
Cheers Oz
Offline nrhs sales
Re: Using a wet nitrous setup on EFI
« Reply #1 on: May 13, 2010, 04:31:42 PM »
Wet nitrous is the only way I would use nitrous for LSR purposes.
Offline joea
« Reply #2 on: May 13, 2010, 04:48:53 PM »
given a choice, fuel from a fuel injector is far
superior to that from a wet nitrous injector...
what is ideal is not always what is best logistically,
meaning much else...can be effective.....
Offline tedgram
« Reply #3 on: May 13, 2010, 07:06:49 PM »
OK,?.
Offline joea
« Reply #4 on: May 13, 2010, 09:26:29 PM »
...adding to the fodder....much like adding to the fogger....
its your choice....
Offline 2fast4u2c
    • http://www.TigerRacingProducts.com
« Reply #5 on: May 13, 2010, 10:04:36 PM »
blew up 4 motors using the wet system.  Now I run dry with no problems so far with EFI and 62# injectors.  (Now I did it, went and said no problems)
EFI and DRY all the way.  I wouldn't even say try it, because I don't want you to get discouraged after you blow up your motor a few times before finally saying "DRY and EFI".
Just my thought and opinions of course, but hey, what do I know.  JoeA speaks truthfully.  Since listening to him, I have been sucessful in not burning up my motors any more.
Guy
300mph or Bust in 1 mile!!!
 Tiger Racing
Offline joea
« Reply #6 on: May 14, 2010, 12:41:40 AM »
...hate to be mr obvious.....but...."guy"  is the guy....
...also please try to understand.....its as much about...how much
increase in hp you want in relation to base engine hp that is more of
a defining line of trouble......vs which way you go with respect to
most issues related, ie richness, timing retard etc......
so many variables, for each application, how long and how much
imho are key.....
all work to a point.....
Offline oz
  • Geordie Power.
« Reply #7 on: May 16, 2010, 06:04:17 AM »
Thanks guys
I aint going to use massive amount of Nitrous probably around 80hp shot the motor "hopefully" should be producing around the160hp mark at the crank before the shot, I hope! ,at least this time i will have time to iron out any problems before we get back to the Salt and should be able to try and see which setup works best.
Cheers fellas. Oz
