Author Topic: scta approved leathers?  (Read 3328 times)
Offline racer
  • Impound 2009. sweetest spot at Bonneville.
« on: May 08, 2010, 01:21:20 AM »
looking for a used but not abused set of leathers that will pass scrutinizing.
5"7", 145 lbs, 31" inseam.
thanks,
raycwheeler@gmail.com
Ray C Wheeler
Offline nrhs sales
Re: scta approved leathers?
« Reply #1 on: May 08, 2010, 09:09:45 AM »
Ray,
You should probably post this in a different section as SCTA approved leathers are much different than Bubs AMA approved leathers.
« Reply #2 on: May 08, 2010, 10:00:27 AM »
I agree.  When I first saw the post I didn't realize that it was aimed at the Bub's event, even though the word "scrutinizing sorta hinted that it was.  Whatever, Ray, consider moving this thread to the Bub's topic.  I can help you there if you don't know how to do it.
Offline saltwheels262
  • LTA 7/2013
« Reply #3 on: May 08, 2010, 12:44:48 PM »
i took it as needing leathers to pass
scta tech. he has run at bub.
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Offline Pippi
  • "do or do not...there is no try"-Yoda
« Reply #4 on: May 14, 2010, 11:44:28 PM »
Just so you know...
AMA BUB leather requirements:
Suits made of synthetic material are not permissible. The
use of stretchable Kevlar and perforated materials in noncritical
areas are permissible. Leather suits shall be onepiece
design or joined by a full circumference zipper at the
waist. Leathers cannot be too big or loose. Critical area
(knees, elbows, forearms, shoulders) armor or 2-layers of
leather is highly recommended. Due to invisible flames,
riders’ of motorcycles burning fuels of Methanol content
are recommended to wear Nomex underclothing or
something of similar nature.
RWB BUB leather requirements:
The use of synthetic material riding suits is prohibited. The use of stretchable Kevlar
and perforated materials in non-critical areas are permissible. Leather suits may be
one-piece design or joined together with a full circumference zipper at the waist, or
separate jacket and pants. Leathers cannot be too big or loose. Critical area (knees,
elbows, forearms, shoulders) armor or 2-layer of leather is highly recommended.
Riders of motorcycles burning fuels of a Methanol content, are recommended to wear
Nomex underclothing or something of similar nature due to invisible flames
-Linnea
BUB Racing Inc
Offline cranberryroo
« Reply #5 on: May 25, 2010, 10:59:37 PM »
How do I know if the fabric inserts in my jacket are stretchable kevlar or something else?
Offline fredvance
  • FVANCE
    • Vance and Forstall Racing
« Reply #6 on: May 26, 2010, 04:13:21 PM »
If you are talking SCTA if it isn't leather it wont fly.
Offline ol38y
« Reply #7 on: May 26, 2010, 04:36:11 PM »
Contact the mfg.?
Larry Cason
2010 BUB 1350 M-PG record
