Eric, I would reconsider using two fuels. One fuel and N2O should achieve your desired result,,, mixing the deal may give you an undesirable ... boom...
Be careful my Friend,
Charles
I am trying to be a careful as I can be.But I am in uncharted territory. Not much hard data on modifying the 250 ninja for real. Jon and Mike have done some with the turbo but I am using a different engine and a different approach.And doing it myself . So any help or advice will be greatly appreciated.I am learning as I go
From the beginning. The 249 cc four stroke engine makes 26 hp stock .It is different from the previous engine because it uses shim under bucket valve train . The old engine used rocker arms.
For the last three years I have tweaked the engine to 33.7 hp (last good dyno run.) Most of the power comes from feeding it lots of fuel and advancing the timing . I got 1 hp just from not tapering the timing off at High RPM . I also have forged pistons and other good stuff.
I have a programmable ignition system with two ignition maps that can be switched with a simple open or closed circuit.My plan is to run 45 deg on map 1 then when I push the nitrous button a relay will switch to map 2 and that map will have 42 deg or so.
I found from dyno testing that 45 deg of advance works best and I use Rocket 100 all the time.
I have not tried running 118 but I GUESS it would loose power If I ran that fuel .I may be wrong there.
I have a thick copper head gasket to lower the compression" some "for the nitrous . But that would make running 118 all the time worse.
I was told to use high octane fuel with nitrous to cool the charge . That way I can get away with more timing advance than otherwise.
Maybe I should can use rocket 100 with the nitrous and It will be OK . That I don't know . My thinking is "somemore " Octane when spraying nitrous would help guard against Knock
As far as switching things during a run .I don't need to switch anything on the run.Fuel runs from the tank to the carbs like normal.Then when I energize the nitrous system .Fuel will be delivered to the solenoids from the electric fuel pump.The solenoids will open with a thumb button and a WOT switch
I run a 1/4 mile in 14 sec .4th gear at 90 mph .I only go 110 in the mile. So I am in 6th gear at the 1/2 mile. I will just spray from the 3/4 mile marker on . That is a 7 second shot. I could spray from the 1/2 mile but that would be for later .(Like Sunday afternoon in October) haha
I will have to start another thread about jetting and pump and bottle pressure for 10 hp on a 15 cubic engine.
