Author Topic: ballast mounting requirements  (Read 2720 times)
Offline DKrause615
« on: April 23, 2010, 10:06:49 PM »
Is it legal to mount lead ballast inside the car?  I plan on using two 1/2" grade 8 bolts per 60 pound lead bar?????
Offline dickj
Re: ballast mounting requirements
« Reply #1 on: April 23, 2010, 10:17:25 PM »
Something to think about.  Unless this is a very low car with underslung suspension, anywhere inside the body is probably going to be too high.  Ballast seems to be most commonly mounted below the axle centerline.
Offline John Burk
« Reply #2 on: April 24, 2010, 02:44:51 AM »
If there is much ballast something to think about is polar moment of inertia . Adding the ballast at the ends of the car increases the polar moment and slows the yaw rate giving the driver more time to react . Sprint cars have the engine and driver close to the cg so the driver can pitch it quickly "sideways" entering a corner .
Offline thundersalt
« Reply #3 on: April 24, 2010, 10:26:37 AM »
What are you bolting it to?
916 REMR
El Mirage 200 MPH Club
Offline Dynoroom
« Reply #4 on: April 24, 2010, 12:03:50 PM »
Yes it's legal to mount this way. Make sure it won't move as the inspectors can / will grab it to make sure it's mounted solid.
