Author Topic: buell fuel injectors  (Read 9265 times)
Offline rascalion
« on: April 13, 2010, 08:33:24 AM »
after using google and bing and searching thru the links, the question about the flow rate or who builds buell fuel injectors eludes me....can anyone help?
Offline k.h.
Re: buell fuel injectors
« Reply #1 on: April 13, 2010, 09:58:21 AM »
Buell DDFI. Buell's Dynamic Digital Fuel Injection
http://buelltuning.free.fr/injang.htm
Also, you might try badweatherbikers.com and ask your questions in one of the tech forums.  Should get a quick answer from some pretty savvy Buell folk.
« Last Edit: April 13, 2010, 10:23:44 AM by k.h. »
Offline firemanjim
« Reply #2 on: April 13, 2010, 02:57:06 PM »
What year and model? And what are you trying to do? ECM Spy has freeware to tune early 08 and older bikes. You would need a connector to communicate with your ecm, American Sportbike sells em.And if you are in NCAL I have dyno shop with lots of Buell experience. Edit, that, see you are in Jackson, my shop is at Infineon(Sears Point) Raceway.
Offline rascalion
« Reply #3 on: April 14, 2010, 08:49:01 AM »
the plan,,..a modified frame, 1000cc, push rod, turbo bike based on an 883cc hd
the goal,,,,W O S this sept
still contemplating blow thru carb vs efi
bought a buell intake manifold w/injectors to help the process,,,my buddy Sam Dakin has installed buell injectors and  micro squirt  system on his turbo xl 1200 hd,,he asked if me if i could find the flow rate for his injectors for tuning ,,thinking this easy ,said sure no problem,,,has turned out not to be the case :?
« Last Edit: April 14, 2010, 09:21:14 AM by rascalion »
Offline Thomas_Cronan
« Reply #4 on: August 02, 2010, 02:57:53 PM »
i have been told that the injectors from the xb's were ford parts?? as to tuning use the ecm spy and mega log program. i have had luck so far, just need a laptop or pda. are they xb9 or 12 injectors? im sure they flow different?
ECTA 200MPH CLUB@215.4MPH ALL MOTOR
LTA 200MPH CLUB@236.9 TURBO
250MPH CLUB MEMBER
Offline firemanjim
« Reply #5 on: August 03, 2010, 02:23:44 PM »
Early tubers were Ford parts,XB's are shorter, IIRC VROD injectors can be made to work and if you are using the Buell tank/pump they offer a different regulator for more pressure and also one from a Dodge V-6 works.Check out the XB board at www.badweatherbikers.com
« Reply #6 on: August 03, 2010, 05:31:20 PM »
ahh well i was told kinda half way right, i have never messed with my injectors because i have never had  a problem. i have thought about when i redo the motor if i should carb it or bigger injectors and throttle body and fuel pump?
250MPH CLUB MEMBER
