I had 3 race cars running this weekend that made a total of 32 passes over a 2 day event.
One of them broke out by .002 in the 8th and final round after winning his class and then racing the winners from 4 categories for king of the hill.
Those are grandsons that represent the 3rd generation of drivers that started with me in 1962.
With 41 SCTA record trophies, I think that represents some time spent with them also.
The 30 years in SDRC have not been without some time dedicated to the effort with suitable results.
If I am at an SCTA meet, I am not likely to check in with you.
Try again
Oh and for Kent. If you want to use a wheel dyno put the car on 1 roller of a full sized chassis dyno and spin their ass off. SDRC meets on top of one now.
The hp should always be measured at the point of delivery because that is where you use it.
A 16V92 is the spec for 2 V8 diesels with 92" per jug that are linked together by the ends of the crankshaft like Nolan's setup. A very common package the was even used in the over the road truck from Battle Mountain that ran Bonneville.
And for you points hustlers, they have to be sharp enough to stick , otherwise they fall on the floor and there will be no cigar.
