Author Topic: WHEEL SPACERS/ADAPTORS  (Read 1924 times)
Offline DKrause615
« on: March 21, 2010, 08:28:14 AM »
I just purchased land speed tires, 15" X 4.5" X 3/8" thick steel wheels and moon hub caps.  WOW$$$$$$$$$$$$$$$$
The rears fit fine, but the fronts, (because the wheel centers are flat), I need to install a 3/4" spacer to clear the brake rotor.  The spacers are readily available and longer wheel studs are no problem.
I just need to know if this is legal????????????
Re: WHEEL SPACERS/ADAPTORS
« Reply #1 on: March 22, 2010, 11:27:35 PM »
should be legal, but I think you may not help your scrub radius.  Sparky?
Offline jimmy six
« Reply #2 on: March 23, 2010, 01:07:11 AM »
I've used spacers for years and never had a problem with tech. Make sure they are properly centered. I actually attach them to the wheel, then put them on...Good Luck
Offline DKrause615
« Reply #3 on: March 23, 2010, 07:50:58 AM »
Thanks for the response.  If I need to, I'll take your suggestions, and run the spacers.
Just for your information I came up with another solution.  Instead of spacing the wheel out, why not move the brake caliper in.
Turns out that many cars run the 5 X4.5" bolt pattern.  The Ford Ranger pick up has this pattern, and the rotors are offset 3/4" back from my current application.   Now if I run 3/4" spacers behind the brake brackets, I have accomplished the same thing without affecting scrub radius.  Hope it works.  Thanks again.
Offline floydjer
« Reply #4 on: March 23, 2010, 10:10:38 AM »
Sounds good :cheers:
« Last Edit: March 23, 2010, 10:44:15 PM by floydjer »
