So I just got my one off window net in from Stroud. Bob and I decided on doing two buckles on the net. One on the front side and one on the top with a bar. On the lower half I actually have a V-shpaed opening. We both decided on using eyelets to secure the net to the roll cage.
Now there is my issue. We came up with two solutions. Use short self tapping screws or drill a hole for each eyelet all the way through and run bolts and nuts. Are either of these solutions ok for SCTA? I am not seeing anything in the rule book stating either is not ok. My gut and 99% of my brain tells me to use bolts and nuts, because if I do screws it will only be secured to on side of the bar. And will have a weak point with the screws possibly coming loose.
The only issue I see that may be pointed out is the drilling of 8 holes on two bars. What do you guys think?
