YaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaHuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu!!!!
Made my first ever alu-welded part, that will actually serve a function on the bike
A combined air-inlet and "keep my knee from interfering the throttle-cable-wheel"-contraption.
Welded tube to flange (is that the term?)
...started at the 'under'-side as tube was right at the edge of the flange
so wanted to do this part first before everything heated up
and I would risk melting the edge of the flange
..and welded the thingy to the flange
That weld isn't too pretty, buy that is solely because thingy is
a different sort of alu, namely a cast-aluminum of some sort, and also quite thinner than the flange.
VERY tricky.
Well, that's my explanation......and I'm sticking to it !
Came out pretty decent. Not good, not bad,
but darn ; I'm pleased .
No burning through the material. No black burns
Just need to sand and polish it up, make a gasket and stick it on the bike.
The air-filter is a mock-up. A size that fits the tube will be mounted
As the famous quote says:
"That's one small step for mankind, but one giant leap for this here man".
