Author Topic: ceramic bearings and ball VS roller  (Read 7188 times)
Re: ceramic bearings and ball VS roller
« Reply #15 on: February 24, 2010, 10:47:54 PM »
A thing to think about when converting from ball to roller bearings.
In many applications the ball bearing inner race(s) and some spacers are on a shaft.  There is a nut on the shaft end and it is tightened down.  The shaft including a portion of the threaded part are in CONSTANT tension.
In the typical roller conversion we use little to no preload.  The shaft and a portion of the threads are in a variable, and sometimes, cyclic state of RELAXATION and TENSION.  Now fatigue life is a concern, and it is especially critical if the rotating component exerts a cyclic load on the shaft.  ie, out of balance wheel, etc.
Usually the parts we work with are over engineered to the degree that this is not a problem, but it should be considered when modifications are made.
On another note, internal friction manifests itself as heat.  Sometimes simple operating temperature comparisons will tell us a lot about bearing type, lube and its application, and preload.  "Cool running = fast running."
This is backwoods engineering, not very sophisticated, just some ideas.
