Honestly dude? A belly pan is a great idea, but only in LSR where weight can actually help.
The weight of the pan will hurt your ET more than any aero gain it would give you.... unless you take your car to B'ville that is.
Answer to the Aero issue AND the weight issue?
1) Lower the front of the car... A LOT. I'm talking cm's of ground clearance. Have someone take a good pic of your car on the top end as you go through the traps at 130mph. You'd be suprised how much acceleration and wind actually lift the front end.
2) Drill holes in anything non-structural (and even some in structural!) areas to lose weight. Think inner body areas.
3) Cut out big chunks of inner door panel, holes in the door jam, the body areas underneath the rear bumper, the front bumper, the radiator mounting sheet metal, inner portions of fender structures, rear floor areas.... ANYWHERE to shave ounces. If you have anything other than a steering wheel and a firewall, a seat, and a fire bottle, its dead weight. Drop it.
THAT will get you those .002 seconds-----and a few more wins.
4) You may want to think of a slightly lower final drive ratio, or a slightly shorter slick. That will also help acceleration, as the physics of better gearing always favor getting that 2k+ lbs rolling quicker. A friend of mine in a 2,800lb car went from a 4.10 gear to a 4.56, and dropped nearly 2 tenths. Top end speed was roughly the same... but he got there in less time.
