I'm in the process of building a gas roadster with a class record of 229 MPH. I thought alot about what I wanted for fire suppression, and for what it is worth, decided on a 10 lb. Firefox Industries water based foam for the engine bay, and a 10 lb. Firebottle Dupont FE 36 system for cockpit. With the fuel tank, hot headers, etc. forward of firewall, I felt the foam system would would work best to not only suppress flames, but also prevent re-ignition of fuel or oil on headers by cooling them during discharge of the bottle. The foam is obvious messy and some say corrosive, but an engine bay can be cleaned relatively easy. The cockpit is another matter, and that's why I went with Halon type around driver.
One thing is certain. With an engine fire at Bonneville, you are going to be on your own for at least a minute or two.
