"...I have heard that you get a lot more runs in at an event when running in a class as opposed to running just for speed."
Every entry is given the same opportunity for runs as wanted. It is first come-first served at the starting line. Your consultant is giving you some bum info.
The pictured car would be very, very difficult to convert to class specs. First would have to be a roll cage to spec. The chassis that these cars use is not compliant with the rules. Depending on engine class the car must be built to the existing record where chassis, tires, fire system, etc. is concerned.
When you recieve your rulebook you will see that there is no J engine break in the Modified Sports classes, so you can save that exercise.
From your posts I will guess that you are planning on the G engine class. Here are some samples of of salt records:
SECTION 6
BONNEVILLE NATIONAL CAR RECORDS
6.A Special Construction Category
Electric Vehicle - /E
Blown Fuel Streamliner - /BFS
G Costella & Yacoucci R. Yacoucci 08/06 348.743
Unblown Fuel Streamliner - /FS
G Barnyard Bearcat J. Talbot 08/09 233.491
Blown Gas Streamliner - /BGS
G Costella Yacoucci R. Yacoucci 08/06 352.525
Unblown Gas Streamliner - /GS
G Barnyard Bomber J. Knapp 10/09 258.988
6.D Modified Category
Blown Fuel Modified Sports - /BFMS
G Autocomponenti B. Lightfoot 08/09 225.839
Unblown Fuel Modified Sports - /FMS
G Besic Motorsports M. Besic 08/04 159.112
Blown Gas Modified Sports - /BGMS
G Autocomponenti J. Steck 08/09 230.352
Unblown Gas Modified Sports - /GMS
G Besic Motorsports C. Bielat 08/04 163.441
Of course, if you plan on the USFRA 130/150 club events the records don't matter. Keep asking questions, I am sure you will find the folks here eager to help.
