Author Topic: Firewall  (Read 2536 times)
Offline 116ciHemi
Firewall
« on: January 08, 2010, 07:23:48 PM »
I use a set of regular gauges and all of the wires run and op line run through a 3/4 ish hole in my firewall. I have a cut up pcv gromet that I use to keep the edges from damaging the lines. My 2009 rulebook says that all holes have to be sealed, and the gromet doesn't seal it. What would qualify as sealing the hole? If I used high temp RTV to seal fill the open area would that be safe?
Re: Firewall
« Reply #1 on: January 08, 2010, 08:22:20 PM »
3M Fire putty, you can get it at Home Depot in small quantities
Re: Firewall
« Reply #2 on: January 08, 2010, 09:24:46 PM »
I'll second that.  Available in caulk tubes.  I'd plan ahead and get all of your holes at once - seems that once it's opened, even capping it off didn't keep it from drying out and getting hard in the tube.
Offline 116ciHemi
Re: Firewall
« Reply #3 on: January 08, 2010, 09:29:02 PM »
About how much? I am on a serious shoestring. Like teenager with no job showstring.  :-D I can usually come up woth the money, but I have to budget for everything.
Offline wolcottjl
Re: Firewall
« Reply #4 on: January 08, 2010, 09:30:56 PM »
A regular caulk size tube is under $10.00
Joel Wolcott
Moving to 2 wheels in 2010
Offline 116ciHemi
Re: Firewall
« Reply #5 on: January 08, 2010, 09:44:15 PM »
Sweet.
Offline White Monster
Re: Firewall
« Reply #6 on: January 09, 2010, 07:37:26 AM »
Sweet.
Is that you Walter ?
I noticed you've increased the displacement of your Hemi ....
 :-D
Be safe, go fast, have FUN !
