A while ago there was discussion on this board about a Jr. Dragster style LSR class. This would be the ideal candidate. Diesel is not as a flammable as gas, and is safer than battery packs in a crash, and there is a reasonably cheap "spec" engine. Engine is sealed with the factory 3600rpm limiter, must be rear mounted, air-cooled, and max weight is 600 lb with driver. One quart fuel tank max, pure biodiesel-only, no electrical system permitted, must be pull-start, and leave the line from a stop. If a bicycle can go 80mph, how fast can a 10HP streamliner go in 2.25mi?
