DW,, thanks for the input,,
I have .080 flat aluminum 1.5 " wide,, was going to brake a 90 degree bend in it to get the max 3/4" rail height.
By moving the rails out.. then I have multiple contours to contend with,, the Studebaker roof is far from flat,,, I will have a front to back contout (no problem,, it does not change the angle),, but the side to side and rolling crown contour chnages the degree... so to keep the vertical rail "straight up" 90 degrees to the ground/sky.. then the angle is more than 90 degrees to the flat bottom mounting surface ??
Charles
