If the engine is being built that close to the limit you must be prepared to pull a head. An engine that close will have to be measured at ambient temp because it will be too big when measured hot.
We use dial verniers to measure and while the quality of some tools is better than others, the person using the tools can be a factor. If the engine is difficult to reach that can also add a few thou to the measurement. A tilted caliper does not read the same as one that is dead-on perpendicular to the bore.
Pistons down in or out of the bore factor into the stroke measurement too.
An engine this close will not be measured with air or oil, the methods are not accurate enough. If it is a center plug head we sometimes use a dip stick that drops into the bore and expands to touch the cylinder walls and a stop is set. The tool is collapsed and withdrawn from the cylinder, it is then opened to the stop and measured with calipers. The stroke is set by bridging the bore and using a rod to set on top of the piston. A stop is set, the crank hand turned and the top of the stroke is set with a stop. The measurement between the stops is the stroke. As you can see there is a large amount of room for error here, especially when the wind is blowing hard, the dust is flying or the rain has begun.
This is all done outside in the elements not in a clean room. Need I stress any more that caution should be exercised when building for a displacement class?
Thank you
Dan W. for your reply, I highlighted in red the points I found to ring true. I had to reread the part in purple about the piston stop bridging the bore on top of the deck. Is this device magnetic or bolted onto the block?
I understand about how the elements are going to play in this,
1 it is going to get into your engine(sand,salt etc.)
2 the conditions play a part in the inspectors willingness to hang from his ankles to get access into a tight engine compartment.In order to make sure the vernier is square to the deck and bore! I got from
Stainless about how it is good to expect a teardown and have a good attitude, Easier for me as I have been a tech inspector for other types of racing in the past.
Sparky thanks for the hint that it would be so close that I should consider airconditioning the block on the return with ice water to shrink the block, I could even hose it down with CO2 but I would think that these kind of activities would arouse quite abit of attention!
Panic brings up the idea of ....where is TDC. What I think he is saying is that it is important for the dial bore gauge or piston stop to be placed on top of the piston in just the right place. If a D.B.G. is used and it doesn't travel exactly parallel with the piston in it's travel the measurement is off. With the stop or the D.B.G. it is also possible to have it located too much on either side of the wrist pin axis causing an overly loose piston to rock in the bore. If the piston rocks unnoticed this could effect the measurement of stroke. So the moral of the story is don't build a loose engine (piston wise) with a wrist pin that is offset alot. As this will show up in more piston rock at T.D.C. Thanks
Mcrat for the tip about the tips of dial bore gauges needing to be fresh.
Doug Odom will now have to live down his typo for calling
D.W. PRETTY........good with the pump! The one post that really opened up my eyes
was what
Nortonist wrote: basically about in 3 different measurements he got a result that varied 2.5cc from 497,498 to 499.5 on I assume a 500cc single? cylinder engine! So with
Willie's prudent suggestion to stay away from the top by at least 3% Iam going to take all of the excellent advice from all of you and use smaller pistons!
Thanks again,
