As I was driving a GM car equipped with computer controlled Babysitting this morning, I realized how good this system really is. When the road was clear, I started to goof off a bit with it. I could not "upset" the car. Not with over 550HP on tap in RWD on summer-performance tires. Just a bit of slip was allowed, but it would not permit the car to go in a direction that the steering wheel was not pointed in. Nail the brakes or mat the gas in a corner? No problemo, nothing abrupt, no surprises.
And it was raining.
This system was first released in 1997, and has gotten better. But even with the first gen systems, I found it controlled spins, oversteer and understeer quite well.
On a roadrace track with the first gen Vette system, I did laps with it on, then turned it off. Yup, I could go about 1.5 seconds a lap quicker with it off, but the second I pulled a boner, I spun. It really does "save yourself from yourself". BTW - I did race with it off most the time, since I was looking to go as fast as possible, but I wanted to see it's effect.
But perhaps the dragstrip was more telling as it would relate to LSR efforts. I have spoke out a lot on the issue at the track, and on the Corvette sites. Yes, you can turn off the Traction Control (but most of you won't go any quicker). But do not turn off the Active Handling. You will not go quicker regardless of your experience level or HP, and you WILL center-punch the rail if you screw up and it's off. That is based on watching a lot of "macho men" and one "I can drive, don't need your advice" lady go home on a flatbed and delay the racing for an hour or more. Luckily an 80mph encounter with the wall won't often injure the driver, but it will total the car. I have run alot with it on and with it off, and it makes zero difference in ET's or trap speeds.
More and more cars are being equipped with this technology, and the price is falling. It uses accelerometers to determine the rotational acceleration, forward and braking rates, then compares it to what the driver is doing with the controls. It uses individual corner braking and throttle reduction to steer the car in the intended direction. ie - if you are holding the steering wheel straight, and the car starts to rotate, it steers the car like a bulldozer.
So if you are running a vehicle so equipped, do not disable the system; you are not roadracing. If you are starting a new "ground up" coupe built, consider using a "rolling chassis" with this system.
Because no amount of impact safety equipment can ever be as safe as not wrecking the car to begin with.
This has been an unpaid advertisement by General Motors, if this had been an actual commercial, broadcasters in your area would advise you to locate a GM dealer near you for further information and news.
